1997 Ford Taurus should I buy new. when I have used?
1997 FORD TAURUS
99,000 MILES • 6 CYL • FWD • AUTOMATIC
PIPES
Hi, I took my 97 Taurus in to get it aligned and when I picked it up, I was told the front bearing was going bad. And a rod was loose. I have another car just like it, that has a busted motor. So the question would be, can I just change out the front drive axle to fix the car? And how hard would it be to do? And would I need any special tools to do it? I'm not very car savvy lol
Nov 13, 2008 at 1:54 AM
BMRFIXIT
  • 19,053 POSTS
FRONT SUSPENSION -1997 Ford Taurus G
Page 1 of 2
HUB & BEARING ASSEMBLY
CAUTION: Do not begin this removal procedure unless a new wheel hub retainer and washer assembly and a new inboard half shaft joint stub shaft circlip are available. Once removed, these parts must not be reused during assembly. Their torque holding ability or retention capability is diminished during removal.
Removal
1.Turn ignition switch to the OFF position and place the steering column in the unlock position. Remove wheel hub retainer. Raise vehicle on hoist.
NOTE: Make sure steering column is in the unlocked position, and do not use a hammer to separate tie rod end from the front wheel knuckle. Use extreme care not to damage boot seal.
2.Remove cotter pin from tie rod end stud and remove slotted nut. Discard cotter pin and nut. Using Tie Rod End Remover (TOOL-3290-D) and Tie Rod End Remover Adapter (T81P-3504-W), remove tie rod end from front wheel knuckle. Remove stabilizer bar link from front shock absorber.
3.Remove disc brake caliper and wire in such a manner as to obtain working space. Do not allow disc brake caliper to separate from the front disc brake caliper anchor plate to prevent contamination of the disc brake guide pin journals. Do not allow disc brake caliper to hang from rear wheel brake hose. Remove front disc brake rotor. Remove front disc brake rotor from wheel hub by pulling it off the lug bolt. If front disc brake rotor is difficult to remove from front wheel knuckle, strike front disc brake rotor sharply between lug bolt with a rubber or plastic hammer.
If front disc brake rotor will not pull off, apply Rust Penetrant and Inhibitor (D7AZ-19A501-AA) to inboard and outboard rotor/hub mating surfaces. Install 3-Jaw Puller (D80L-1013-A) or equivalent and remove front disc brake rotor by pulling on front disc brake rotor outside diameter and pushing on hub center. If excessive force is required for removal, check front disc brake rotor for lateral runout prior to installation. See appropriate DISC & DRUM article in BRAKES. Lateral runout must be checked with lug nuts clamping hat section of front disc brake rotor.
4.Remove anti-lock brake sensor mounting bolt and front brake anti-lock sensor. Remove and discard lower ball joint nut. Using Ball Joint Remover (T96P-3010-A), separate lower ball joint from front suspension lower arm.
5.Using Rotunda Spring Compressor (164-R-3571), compress front coil spring until lower ball joint clears front suspension lower arm. Using Front Hub Remover/Replacer (T81P-1104-C), Two Stud Adapter (T86P-1104-A1), Metric Hub Remover Adapter (T83P-1104-BH) and Front Hub Installer (T81P-1104-A), press front wheel driveshaft joint from wheel hub. Wire front wheel driveshaft joint to body to maintain a level position.
6.Remove and discard three hub and bearing retainer bolts from front wheel knuckle. Wheel hub is not pressed into front wheel knuckle. DO NOT use slide hammer to remove a stuck wheel hub. Do not strike back of inner bearing race. Use of these methods will damage bearing internal parts. If bearing carrier is corroded to front wheel knuckle, apply Rust Penetrant and Inhibitor to the inboard and outboard wheel hub/knuckle mating surface and allow to soak.
Remove wheel hub from front wheel knuckle.
NOTE: If wheel hub is damaged or if any end play is detectable, replace wheel hub. End play is not adjustable. If wheel hub is disassembled, the assembly must be replaced.
CAUTION: Knuckle bore must be clean enough to allow wheel hub to be completely seated by hand. Do not press or draw wheel hub into place.
Installation
1.Remove all foreign material from knuckle bearing bore to ensure correct seating of new wheel hub. Lightly lubricate mating surfaces of bearing corner and front wheel knuckle. Position wheel hub in front wheel knuckle. Install three new hub and bearing retaining bolts. Tighten to specification. See TORQUE SPECIFICATIONS .
2.Push front wheel driveshaft joint into wheel hub. Hand start front wheel hub retainer. Slowly release Rotunda Spring Compressor (164-R-3571) while guiding lower ball joint into front suspension lower arm. Install new lower ball joint nut. Tighten to specification.
CAUTION: Use extreme care not to damage boot seal. Do not use power tools to tighten nut, or bearing and seal damage will result. Install nut using hex hold feature to prevent the stud from rotating.
3.Install tie rod end into front wheel knuckle. Install new slotted nut and tighten to specification. See TORQUE SPECIFICATIONS . If necessary advance nut to install a new cotter pin.
4.Install stabilizer bar link to front shock absorber. Install stabilizer bar link nut. Tighten to specification.
5.Install front disc brake rotor and disc brake caliper. Tighten caliper anchor bracket bolts to specification. Install wheel hub retaining nut. Tighten to specification. Install wheel and tire. Tighten lug nuts to specification. Lower vehicle. Pump brake pedal prior to moving vehicle to position brake linings.
Need a tool or a tester CHECK IT @
http://www.2carpros.com/affiliate/uid/bmrfixit_1
need manual CHECK IT @
http://www.2carpros.com/kpages/auto_repair_manuals.htm
Nov 13, 2008 at 12:08 PM
