1997 Ford Taurus Shorted ignition wire now gauges won't wor
155,000 MILES • 6 CYL • FWD • AUTOMATIC
LAUGH
When hooking up a remote starter I accidentally shorted the ignition wire now the speedometer, tachometer, cruise control, rear defroster, and heater temperature control will not work. All other gauges and electrics work fine. I have checked all fuses. Main ignition fuse under hood was blown but I replaced it. Car starts runs and shifts as it should. The remote starter works great so I know it is geting the tach signal. I have tried disconnecting the remote starter and still the same.
Mar 23, 2009 at 1:13 PM
BMRFIXIT
  • 19,053 POSTS
Test the ignition switch and its wires if all have power on with key on (if not suspect bad ignition switch )
you should have the wiring schematic from the remote starter
recheck fuses with car running or key on
Mar 23, 2009 at 1:28 PM
LAUGH
Ignition switch was disconnected when wire was shorted. I have a 99 taurus as well. I could swap parts. Anyone know if the gauge clusters are compatible with 97 and 99. Perhaps the shorting just damaged the cluster and the switches for the rear defrost and heater temp control.
Are you suggesting that I check all fuses for power with key on. Or just the ones I suspect are for the components not working?
Mar 23, 2009 at 1:39 PM
