1997 Ford Taurus shifting
97,000 MILES • 6 CYL • FWD • AUTOMATIC
JACKIE SHUMSKY
replsced the rotors,pads,caliphers,shoes
and put in new brakes lines ...the problems is now
i start the car up and i can't shift to drive becasue the break pedal won't disengage the gear shift
Jun 17, 2008 at 10:53 AM
BLACKOP555
  • 10,386 POSTS
for a temp fix, try to turn they key right before the car is on and try to shift it to neutral then precede to starting, try this in different key positions till you get it.
are your brake lights workign?
Jun 17, 2008 at 1:25 PM
