1997 Ford Taurus RPMs
160,000 MILES • V8 • 2WD • AUTOMATIC
JAYBMF
Twice now my RPMs have dropped so low the car nearly cut off on me while idling. Once, the a/c cut off. When I accelerate after this, the car acts as if it were in neutral. Any suggestions? I was told to check my air filter, but I'm not sure.
Sep 13, 2010 at 2:34 AM
  • 110,248 POSTS
Has the check engine light come on? Have you checked for vacuum leaks? Have you checked fuel pump pressure?
Let me know what you find.
Sep 13, 2010 at 2:35 AM
JAYBMF
Check engine light doesn't turn on, and the fuel filter is doing okay. I'm not sure how to check vacuum leaks.
Sep 13, 2010 at 3:21 AM
  • 110,248 POSTS
Check the hoses on the engine for being disconnected, dry rotted, or wear.
Sep 13, 2010 at 5:28 AM
