HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Taurus
Engine
Symptoms
Idle High
SPONSORED LINKS
1997 Ford Taurus Revs up while driving
PREV
1
2
NEXT
MECHANIC
Legitimate007 has given you the probabilities and me following it what's missing to cause this problem and still not working-Last place for me is to reflash the computer
Wednesday, March 31st, 2010 AT 4:30 PM
PREV
1
2
NEXT
Please
login
or
register
to post a reply.
Related Engine Idle High Content
1997 Ford Taurus Heat Problem
Heater Problem 1997 Ford Taurus V6 Front Wheel Drive Automatic 100000 Miles Hi My Problem Is This I Have Replaced Thermostat, Flushed...
Asked by
ELK1090
1 ANSWER
1997
FORD TAURUS
411 Code And High Idle
1995 Taurus Gl 3.0l Wagaon W/110,000 Miles. Maybe Someone Can Give Me Some Help? I Recently Had My Transmision Fixed At An Aamco Dealer And...
Asked by
car*man
1941
FORD TAURUS
2000 Ford Taurus Car Revs Up While On The Brake
When I Am At A Light Or Stop Sign, And If I Have The Front Window Defrost On Or The Air Conditioning (not The Heat For 'floor'), The Car...
Asked by
susannasusannavv
2000
FORD TAURUS
412 Code Ford Tarus '92 Obd1 Cannot Control Rpm Koer...
Ok You Geniuses.I Bought A 1991 Ford Tarus 137k On It. Check Engine Light On.I Ran 3tests Obd1 Ford Says Code412 Cannot Control Rpm During...
Asked by
cmzannn
1992
FORD TAURUS
1998 Ford Taurus High Idle
My 98 Ford Taurus With The Dohc V6 Idles About 2200 Rmp When I First Start The Car Then After About 10 Sec. Then It Idles Down To 1500 Rpm...
Asked by
john doe wny
1998
FORD TAURUS
VIEW MORE
SPONSORED LINKS
Vacuum Leak
Vacuum Leak Test and Repair
Vacuum Leak Symptoms
Online car repair manuals
