HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Taurus
Interior
Radio
Not Working
1997 Ford Taurus radio and driver side window
NNV
MEMBER
1997 FORD TAURUS
6 CYL
2WD
AUTOMATIC
152,000 MILES
Radio doesn't work as same as driver side window won't goes down.
Wednesday, May 6th, 2009 AT 3:00 PM
BMRFIXIT
MECHANIC
Its a separate issues
check fuses on the radio
suspect window motor ,switch and or a wire
have to check if power getting to motor
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
SPONSORED LINKS
Wednesday, May 6th, 2009 AT 9:05 PM
Please
login
or
register
to post a reply.
Related Radio Not Working Content
Radio And Steering Problem
I Have The Car Listed Above With 106,000 Miles And A 3.0 Liter. The Problem Started When I Put It In Reverse The Radio Would Quit (the...
Asked by
derdenn
1997
FORD TAURUS
1997 Ford Taurus Radio Problem
1997 Ford Taurus I Pulled Out Radio Panel And Changed The Switch For Air Flow. I Put All Back In Now Radio Does Not Work And I Can...
Asked by
Bonnie Yesse
1 ANSWER
1997
FORD TAURUS
1997 Ford Taurus Stereo
I Have A 1997 Ford Taurus, And My Radio Works But Where My Clock And Radio Station Is Supposed To Show It Doesnt, Also My Cassette Deck...
Asked by
sjaarv
1 ANSWER
1997
FORD TAURUS
Radio
Have A 1997 Ford Taurus, Radio And Clock Dont Work. Checked The Fuses And Replaced The Radio And Still Have The Same Problem. Help Please
Asked by
mantelfire
1 ANSWER
1997
FORD TAURUS
Interface Control Module - Radio Does Not Work
My Climate Control Does Not Work, The Radio Does Not Work. I Was Told That My Interface Control Module Was Bad.
Asked by
janshe07
1 ANSWER
12 IMAGES
2011
FORD TAURUS
VIEW MORE
SPONSORED LINKS
How to Use a Test Light
Airbag Removal - Drivers Side
Steering Wheel Removal
Online car repair manuals
