the pads grab, but will not release
105,000 MILES • 6 CYL • FWD • AUTOMATIC
BLACKBROBARON
I replaced my rear brake pads and replaced a rotor. the side where the rotor was replaced, when driving down the road, I hear a humming and smell heat. I get back and take the tire off, I step on the brake peddle, the pads grab, but will not release. I did not know how to bleed the lines of brake fluid. I want to know why the pads wont release. can you help me?
Jan 11, 2008 at 9:19 AM
SQM
  • 6,383 POSTS
The brake pad will stick to the rotor when the piston of the brake caliper does not retract back. This is typically due to a brake hose which has collapsed on the inside and creating restriction and preventing the brake fluid to flow back through the hose, resulting a sticking brake pad.
In order to get this fixed you will have to replace the brake hose. Any time the brake sticks for a period of time it is also recommended to replace the caliper, as high heat has likely damaged the internals of the caliper.
https://www.2carpros.com/articles/brake-caliper-replacement
Keep in mind that anytime the caliper or hose gets replaced, the brake system needs to be purged of any air by bleeding the brakes.
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
I have attached the brake caliper and hose replacement as well as the brake bleeding procedure for your reference.
Oct 14, 2021 at 2:46 PM
