1997 Ford Taurus low effiecenty catalyst bank two
163,000 MILES • 6 CYL • FWD • AUTOMATIC
FRIBLEY
We replaced the cataylitic converters on october of 07 because of low effiency in bank two. This past spring we replaced the whole assembly y-pipe again due to low effiency of catayalist in bank two again. In August we repalced the H2os in bank two after the cat and the check engine lite is back on again. The cats were replaced under warranty and the shop was told by the supplier that the cat was bad. Is it possibe that the cat is bad in the replaced unit as well. It seems to go about three months and the light comes on. Two of the four H2OS have been replaced one a couple of years ago. That one is the front one that can be seen when looking down at the front exhaust manifold at the front of the engine.Any ideas would be helpful.
Oct 24, 2008 at 11:56 AM
BLACKOP555
  • 10,386 POSTS
you could have gotten a bad convertor.
but chances are is somethigns cuasing them to fail, such as a exhaust leak causing a rich fuel mixture causing the convertor to overheat and burn up, or you could have a missfire or fouled plug not properly burning the fuel mixture causing rich fuel to get in to the convertor and overheat it.
Oct 24, 2008 at 4:57 PM
