1997 Ford Taurus hesitation
87,000 MILES • 6 CYL • 2WD • AUTOMATIC
JERRYBEHNKE
when i step on the accelarator the car hesitates or chugs but if i floor the accelarator it doesnt> do u think it might be the mass air flow censor or the fuel pump or a vaccum line or anything else? or maybe the computer needs to be reset after haveing the crank censor changed?
Mar 20, 2009 at 3:54 AM
BMRFIXIT
  • 19,053 POSTS
do u have a check engine light on
and if so get the codes
check exhaust flow
check fuel pressure
Mar 20, 2009 at 6:34 AM
JERRYBEHNKE
no there is no check engine light.
Mar 24, 2009 at 4:58 AM
BMRFIXIT
  • 19,053 POSTS
DID YOU CHECK pcv VALVE AND FOR VACUUM LEAKS ?
ALSO DO A FUEL PRESSURE TEST
CHECK IT FOR TUNE UP
CHECK FOR PENDING CODES
Mar 24, 2009 at 10:28 AM
13 JEROME
  • 7 POSTS
you most have changed the spark plugs. if so then it your mass air flow did not tieten right.retieten it and it will run great.(the big thing on top with small bolts).tieten to 35 lb of pressure.some thing happen me i thought it was valve,sensors all of that.
Mar 25, 2009 at 6:20 AM
