1997 Ford Taurus flooded
12,130 MILES • 6 CYL • 2WD • AUTOMATIC
DAVEMA444
i drove into a flooded street. the car stalled. i tried to start it, when nothing happened, i left it alone til the water in the street went down. i was able to start it after a few cranks. i waited about ten minutes in between each crank. so it started, and then i drove the 1.5 miles home . by this time it was raining hard again and i couldnt hear how terrible the motor sounded. so it sat overnight and the next morning it sounded terrible.
it appears i have an oil leak too which i'm not sure was related. i put 2 quarts in. on the 3rd quart it started to leak out. so it has been towed and is getting looked at.
should i expect to use this vehicle anymore ? any hope ?
Dec 14, 2009 at 10:18 PM
BMRFIXIT
  • 19,053 POSTS
Should have it looked at as if engine sound very noisy and you have all kinds of leaks
will not be surprise if engine is bad
Dec 15, 2009 at 2:07 PM
