check fuse # 9 in underhood fuse/relay box
check wiring to or replace
Engine Coolant Temperature (ECT) Sensor (3.0L 2V)Above left side of engine block, near thermostat.
Engine Coolant Temperature (ECT) Sensor (3.0L 2V FFV)Above left side of engine block, near thermostat.
Engine Coolant Temperature (ECT) Sensor (3.0L 4V)Above left side of engine block, near thermostat.
Engine Coolant Temperature (ECT) Sensor (3.4L SHO)Above left side of engine block, near thermostat.
check
Engine Cooling Fan Dropping Resistor....Inside right front bumper, in front of washer reservoir
Jan 2, 2009 at 3:23 PM
