1997 Ford Taurus fans wont turn on
170,000 MILES • 6 CYL • FWD • AUTOMATIC
APOCOLYPS987
i dont know if this is a fuse problem...and if so what fuse to change...
Jan 2, 2009 at 2:36 PM
DAVE H
  • 13,383 POSTS
check fuse # 9 in underhood fuse/relay box
check wiring to or replace
Engine Coolant Temperature (ECT) Sensor (3.0L 2V)Above left side of engine block, near thermostat.
Engine Coolant Temperature (ECT) Sensor (3.0L 2V FFV)Above left side of engine block, near thermostat.
Engine Coolant Temperature (ECT) Sensor (3.0L 4V)Above left side of engine block, near thermostat.
Engine Coolant Temperature (ECT) Sensor (3.4L SHO)Above left side of engine block, near thermostat.
check
Engine Cooling Fan Dropping Resistor....Inside right front bumper, in front of washer reservoir
Jan 2, 2009 at 3:23 PM
