1997 Ford Taurus exhaust noise
156,000 MILES • 6 CYL • 2WD • AUTOMATIC
ALEXPESIK1
There's a noise upon initial start up that sounds like it is coming from some where near where the exhaust ties in with the manifold. It sounds like a small leak, like air escaping from somewhere. It's really annoying. It is more prevalent at start up and significantly decreases as the engine gets up to normal operating temp. Where should I start to look?
Oct 31, 2010 at 8:06 AM
  • 110,248 POSTS
Does it sound almost like a ticking?
Nov 2, 2010 at 12:57 AM
ALEXPESIK1
Not exactly. More like a suppressed pressure sound. I can't pin it down to exactly where, just a general area.
Dec 6, 2010 at 10:05 AM
  • 110,248 POSTS
If there is a leak where the exhaust and the manifold are located, many times you will see a black carbon build up where the leak is located. Check for that. Also, make sure everything is tight. What you have described sounds like an exhaust leak. Also, check for cracks in the exhaust manifold itself.
Dec 7, 2010 at 6:56 AM
ALEXPESIK1
Thanks, will follow up and check everything you suggested. Will post back shortly with my results.
Dec 14, 2010 at 10:07 PM
  • 110,248 POSTS
One last thing, check where the exhaust manifold attaches to the exhaust system. They can leak there too.
Dec 15, 2010 at 5:18 AM
