Engine timing should be 10 Deg BTDC at idle (800 RPM) and is registering 28 deg BTDC. Car seems to run OK so I guess PCM is adjusting to keep car running.
What would cause timing to be so high at idle? Could it be a stretched timing chain, a bad PCM, a bad timing sensor???????
It is also throwing codes P0402 and P0430. I am asuming this is related to the timing performace issue being screwed up.
Please let me know what you think the timing issue may be caused by.
Sep 27, 2008 at 4:47 AM
