1997 Ford Taurus engine performance
GEEWHIZ105
  • 1997 FORD TAURUS
  • 6 CYL
  • FWD
  • 140,000 MILES
I have a 1997 ford taurus press on the gas pedal the car starts put into gear the stalls install new drive belt same problem notice transmission fluild leak ground
Saturday, May 16th, 2009 AT 3:40 PM
  • 109,921 POSTS
I doubt the trans leak is causing the engine to die. Has the check engine light come on?
Tuesday, May 19th, 2009 AT 6:18 PM
GEEWHIZ105
  • 8 POSTS
Yes had check engine light checked indicated air pump
Wednesday, May 20th, 2009 AT 8:29 AM
  • 109,921 POSTS
Is the air pump still functional?
Thursday, May 21st, 2009 AT 7:47 AM
GEEWHIZ105
  • 8 POSTS
How do you check the function of the air pump do this cause the car to stall when put into drive
Friday, May 22nd, 2009 AT 6:59 PM
  • 109,921 POSTS
If it isn't locked up, it should be working. And, I don't believe it would cause the car to die.
Saturday, May 23rd, 2009 AT 2:19 PM
GEEWHIZ105
  • 8 POSTS
What things should I checked that cause the car to die once place into gear
Sunday, May 24th, 2009 AT 4:58 PM
