1997 Ford Taurus eletrical
139,000 MILES • 6 CYL • FWD • AUTOMATIC
CHLOE'S DAD
put windshield washer fluid in tank pressed button noticed a busted hose sprayed all over engine. tried to start car 20min later wouldnt start starter would not even click over/engage please help thanks in advance.
Jun 18, 2010 at 2:30 PM
  • 75,988 POSTS
No cranking nothing at all
If the battery and connection are good the following could be the caused, starter, starter relay, transmission range switch and ignition switch
When you turn key to run do you see all the idiot lites that normally comes on-if not start at the fusible links
Jun 18, 2010 at 8:01 PM
