1997 Ford Taurus Does not blow warm or hot air
151,250 MILES • 6 CYL • FWD • AUTOMATIC
JACK24
The AC works great. Changed thermostat still no warm air will come out of the vents.
Had a mechanic think the "flap" might be stuck but can not locate the "flap" to control warm/cool air.
Can you help???
Oct 28, 2008 at 10:56 AM
BMRFIXIT
  • 19,053 POSTS
Check heater hoses if they both hot
if not you need to flush the heater core
if both hot suspect blend door actuator
its on the HVAC box check it and or have it replace
need manual CHECK IT @
http://www.2carpros.com/kpages/auto_repair_manuals.htm
Oct 28, 2008 at 2:24 PM
