1997 Ford Taurus cooling fan switch
188,000 MILES • 6 CYL • 2WD • AUTOMATIC
TITO603
i have looked everywhere but i cant find exactly where the cooling fan switch is located. Do you have any idea?
Nov 8, 2008 at 7:58 AM
BMRFIXIT
  • 19,053 POSTS
Coolant temperature sensor
is located at near the thermostat housing
no need for fan switch sensor give reading to the PCM
and when fan s needed the PCM will ground the relay turning on the fans
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Nov 8, 2008 at 3:13 PM
