Engine Cooling problem
1997 Ford Taurus 6 cyl
I have a coolant leak behind the water pump at the gasket between the block and the pump base (timing belt cover?). It appears that it is not the the water pump gasket, but the one behind it. I was assuming that I just needed a new water pump, but noticed the leak was farther back. (no leakage at the seep holes on the pump) Am I in for a more serious job? I don't have access to a diagram. Any ideas?
thanks.
thanks.
Jan 3, 2009 at 1:03 PM
