1997 Ford Taurus compatability
RHOE
Transmission problem
1997 Ford Taurus 6 cyl Front Wheel Drive Automatic
Is a 96 ford taurus tranny compatable with a 97 ford taurus? Both are 6 cylinder, also is a 97 taurus 3.0 motor compatable with a 97 mercury sable 3.0, will it bolt up to the mercury tranny?
Jan 2, 2010 at 9:57 AM
BMRFIXIT
  • 19,053 POSTS
If I recall correct 96 came with couple different tranny
AX4S and AX4N
97 was AX4N
check if tranny the same
check with local used part store they should have all you need for info
Jan 2, 2010 at 12:12 PM
