1997 Ford Taurus Cold engine drive problem
168,000 MILES • 6 CYL • FWD • AUTOMATIC
VHANEK
Cold engine - start OK, idle OK in neutral, but when shift into the Drive engine will die. Shift into Reverse - no problem. Restart possible only with fully depressed gas pedal. Driving with cold engine - idle RPM going up and down when shifted in Drive. After engine is heated up enough, all problems disappear. I have to let engine run for 15 min in the morning and then I can shift and drive with no problems. Thank you for advice.
Jan 29, 2008 at 12:50 PM
2CARPRO JACK
  • 11,533 POSTS
Check for broken/cracked vacuum lines. Also using carb cleaner, carefully spray the intake boot between the throttle body and the Mass Airflow Meter (air filter box) to see if it has any cracks in it.
Jan 29, 2008 at 11:41 PM
