Cold engine - start OK, idle OK in neutral, but when shift into the Drive engine will die. Shift into Reverse - no problem. Restart possible only with fully depressed gas pedal. Driving with cold engine - idle RPM going up and down when shifted in Drive. After engine is heated up enough, all problems disappear. I have to let engine run for 15 min in the morning and then I can shift and drive with no problems. Thank you for advice.
Jan 29, 2008 at 12:50 PM
