1997 Ford Taurus car wont stop
FELECIA DAVIS
  • 1997 FORD TAURUS
Brakes problem
1997 Ford Taurus Front Wheel Drive Automatic
i changed the master cylinder on my car. Got on the highway the other day and hit the brake and my car wouldnt start other than the master cylinder what else could it be
Tuesday, June 8th, 2010 AT 7:50 PM
Is it cranking over and will not start or just won't crank at all/nothing?
Tuesday, June 8th, 2010 AT 7:58 PM
JUSTDON
  • 150 POSTS
I think they meant to say that it wouldn't stop after applying brakes. Sounds like maybe a system bleed didn't follow the master cylinder replacement.
Sunday, June 13th, 2010 AT 6:19 AM
BADWUFF
  • 13 POSTS
Take your car to any good mechanic and have them pressure bleed the system. Your brakes will work like new.
Monday, June 14th, 2010 AT 9:57 AM
Check the brake hose, check valve and the booster if its leaking-could be creating a massive vacuum leak-bleeding manually, vacuuming or power bleeding has nothing to with no start-when it starts this when the power brake booster comes in place
Monday, June 14th, 2010 AT 3:34 PM
