1997 Ford Taurus car wont start
MANNYCALI
  • 1997 FORD TAURUS
  • 6 CYL
  • 103,000 MILES
My 97 ford taurus wont start the lights turn on but it wont even start I bought a new starter because it was bad but now it wont start please answer back please
Saturday, September 5th, 2009 AT 2:19 PM
MERLIN2021
  • 17,250 POSTS
When you say it has trouble what kind? Clicking? Or nothing at all? If you hear a click, then either the battery is weak, or the starter, possibly bad battery cable connections, check and clean both ends of BOTH cables! Dissconnect negative(-) first, and put it on last! If no click the starter relay is no good! Does it turn over(crank)?
Saturday, September 5th, 2009 AT 2:54 PM
MANNYCALI
It does click but we switched batteries and it works on another car so it cant be the battery how many wires does a starter have? What is a starter relay?
Saturday, September 5th, 2009 AT 3:10 PM
MERLIN2021
  • 17,250 POSTS
Follow your Positive battery cable, it takes you to the strter solinoid, try crossing the small red/green wire terminal marked "S" to the post with the batt cable attached to it, do it with a pair of needle nose pliers or a large diameter wire, dont dissconnect any wires from the solinoid, have the key in the on position, if car starts replace the solinoid.
https://www.2carpros.com/forum/automotive_pictures/62217_solenoid_1.jpg
Saturday, September 5th, 2009 AT 3:16 PM
