1997 Ford Taurus Can't shift gear from park, p/windows, rad
OKUKAR
1997 Ford Taurus 6 cyl Front Wheel Drive Automatic
The car is stuck in the Park position (it's impossible to shift gears). The engine runs, but... no radio, no power windows, no winking lights. Does anyone understands what this means? Are all those devices connected through the same fuse?
Please help if this info is sufficient.
Nov 21, 2008 at 8:23 AM
BMRFIXIT
  • 19,053 POSTS
I would suspect bad ignition switch
but 1st you need to check all fuses
and check if u have brake light check brake light switch
check fuses
need manual CHECK IT @
http://www.2carpros.com/kpages/auto_repair_manuals.htm
Nov 21, 2008 at 8:28 AM
