1997 Ford Taurus blows cold air
RICHARD HARTLEY
Heater problem
1997 Ford Taurus 6 cyl Front Wheel Drive Automatic
the heater/defrost blows cold air until i take the hose loose on the heater core(return to the thermostat housing) when coolant starts to flow i get good heat. Iput the hose back on and it cools off. The car is not running in a overheat state and i've already replaced the pump, thermostat, heater core, and entire heat box under dash. I've also flushed the coolant system. Any suggestions would really be helpful since i;ve gotten to the end of mine and beating my head against my garage door......thanks
Dec 7, 2008 at 4:12 AM
BMRFIXIT
  • 19,053 POSTS
Check the connector where the removed hose was
if it is clogged
is it the connection by the thermostat housing
do a head gasket test
need manual CHECK IT @
http://www.2carpros.com/kpages/auto_repair_manuals.htm
_________________
Dec 7, 2008 at 10:16 PM
