1997 Ford Taurus Battery
15,400 MILES • 6 CYL • FWD • AUTOMATIC
RILEY2004
My battery died and when I jump start it it will not hold the charge. How can I tell if the battery is actually dead or if it is a problem with the alternator?
Nov 11, 2008 at 10:15 AM
  • 31,937 POSTS
HI there,
The battery should be bench charged and load tested, this is the only true test for battery condition, the alternator can be quickly tested with a volt meter, you want around 1.3-14.5 volts at the main terminal when running, this will depend on battery condition and load demand.
mark (mhpautos)
Nov 11, 2008 at 11:06 AM
