1997 Ford Taurus alternator not charging.
233,000 MILES • 6 CYL • 2WD • AUTOMATIC
SKEETER&SUZANNE
Tested alternator, alternator tested good, but it will not charge a battery, and battery is good.
Aug 12, 2008 at 3:44 PM
  • 31,937 POSTS
Hi there,
If the alternator is charging, you will have a fault in the wiring between the alt & the battery, i will check the wiring and re post if i can find something that may cause this problem.
Mark (mhpautos)
Aug 12, 2008 at 3:56 PM
