1997 Ford Taurus 97 Taurus PO352
126,770 MILES • 6 CYL • FWD • AUTOMATIC
ROBF4130
Went to start the car, turned over, would pop once and then nothing. Had spark and fuel pressure, tried ether and still nothing. Tried a few more times until battery died, then got it started jumping it. Ran real rough, flashed PO352, and died out. Changed coil pack and plugs (newer wires), still same issue. Switched wires, still same code PO352. Cleaned and checked CMP and CKP both working fine. Am I looking at an ECM issue?
Jan 20, 2009 at 5:36 AM
BMRFIXIT
  • 19,053 POSTS
Check fuses and relays
are you sure you have spark on all cylinders
check wiring harness and coil connector plug
Jan 20, 2009 at 10:20 PM
ROBF4130
ran extended spark test this time, no spark on #1 & #5. all fuses and relays good, wiring and connection good
Jan 21, 2009 at 3:02 AM
BMRFIXIT
  • 19,053 POSTS
was the coil changed if not
change the coil
Jan 21, 2009 at 9:54 AM
