1997 Ford Taurus 97 ford tarus/skips
SHERRYM4AU
1997 Ford Taurus Automatic 140000 miles
i have a 97 ford taurus and it has been skipping while driving at first it seemed like it would just do it while going up a hill or incline but now seems to be doing whenver not a big jerk but you can feel it like skipping a stone across water.
Feb 15, 2010 at 1:43 PM
  • 75,988 POSTS
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Feb 15, 2010 at 2:02 PM
