1997 Ford Taurus 1997 Ford Taurus, replaced NSS, now gears
13,000 MILES • 6 CYL • FWD • AUTOMATIC
STEVEF4744
I replaced the Neutral Safety Switch but now I dont have park. North of park is reverse, park is neutral, reverse is drive and so on. What the heck did I do wrong? Please help.
Jan 24, 2009 at 1:21 AM
STEVEF4744
This reply is for those of you who may have the same problem. I did failed to put the shifter in Neutral before I removed the neutral safety switch. I corrected this by keeping the car in park, remove shifter cable from neutral safety switch, then moved shifter to neutral, replace shifter cable. Works good now.
Jan 24, 2009 at 10:12 AM
