1997 Ford Taurus 1997 Ford Taurus
MARIE_MICHAEL1
1997 Ford Taurus 6 cyl
What has been occurring is I would go to start the car, the car would not start, a male who assisted me when stuck got into the car, placed key in car and put in on position, put his foot onto the brake and pull the arm down and back up again, he then turned the key further and the car started. He stated the arm was going off the gear track.
This began to happen more frequently and in him having shown me what to do I have had to do this alot.
I had the starter replaced but would like to replace the arm as it is extremely loose as a result of my having to do this so frequently.
I do not know the name this part would be referenced as to have it replaced. Would you be able to tell me what this part is called??? I need a new arm to take car out of park into drive, or reverse, etc.
Mar 6, 2009 at 6:58 AM
BLUELIGHTNIN6
  • 16,542 POSTS
You're referring to the gear selector lever. I would suspect a stretched/faulty gear selector cable rather than the selector lever itself. You may want to inspect it a little more before replacing a part that may not be faulty..
Thanks for using 2CarPros.com!
Mar 6, 2009 at 7:12 AM
