HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Taurus
Engine
Symptoms
Idle Rough
1997 Ford Taurus
TONYM1938
MEMBER
1997 FORD TAURUS
V8
FWD
AUTOMATIC
166,000 MILES
Why does my car idle rough? When idling, RPM's fluctuates from 600 to 3000 constantly.
Friday, May 8th, 2009 AT 10:50 AM
BMRFIXIT
MECHANIC
Check engine light ON !check for codes
check for vacuum leaks
check pcv valve and its hose
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
SPONSORED LINKS
Friday, May 8th, 2009 AT 7:16 PM
Please
login
or
register
to post a reply.
Related Engine Idle Rough Content
Rough Idle
Have A 1997 Ford Taurus Sho I Was Wondering What Could Be Causing A Rough Idle, I Have Changed Plugs Did Visual Inspection Of Coil Packs So...
Asked by
kevinloken
1997
FORD TAURUS
GUIDE
Rough Engine Idle
A rough engine idle condition is a common issue that many drivers face often indicating underlying problems within the engine, fuel or ignition system. We have created this...
1997 Ford Taurus Rough Idle
Hello, I Have A 1997 V-6 Ford Taurus That Idle Really Rough 95% Of The Time. Other Than Idle The Car Runs Fine. I Have Replaced The Spark...
Asked by
fjbarboza83
1 ANSWER
1997
FORD TAURUS
1997 Ford Taurus Rough Idle At Start Up And Raw Gas...
My 97 Ford Taurus Gl 3.0 Occasionally At Startup (either Cold Or Warm) Will Rough Idle And Sometimes Stall, And When It Does That Ill Have...
Asked by
ryan.smith
1997
FORD TAURUS
1997 Ford Taurus Ac Causing Rough Idle
My 1997 Ford Taurus Has Surging And Rough Idle Issue When The Ac Is On. It Seems To Have The Same Issue To A Lesser Extent With The Heat On...
Asked by
EdMiller
1997
FORD TAURUS
My Car Is In Getting Safetied And The Mechanic Just Called Me To Let Me Know It Has A Miss In The Engine Well It Idles Rough Just Enough To...
Asked by
kevinloken
1997
FORD TAURUS
VIEW MORE
SPONSORED LINKS
Vacuum Leak Test and Repair
Vacuum Leak Symptoms
Vacuum Leak
Online car repair manuals
