Engine Mechanical problem
1997 Ford Taurus 6 cyl Front Wheel Drive Automatic
If you wreck and hit back quarter panel ofthe drives side would the fuel injection system shut down completely when hit?
Wednesday, September 17th, 2008 AT 5:31 PM
2CARPRO JACK
MECHANIC
It sure will. There is an inertia switch to shut down the fuel system in case of a leak when hit. It is located in the right rear cargo area behind the wheel well. Ther eis a reset button to push, then the fuel pump will work again, but check for leaks before driving
