Battery New, Positive and ground cables new, Starter bench tested ok. Vehicle makes no indication of starter engagement when in start position. I removed Solenoid terminal and performed voltage tests, 4.43 volts in start position and -3.43 volts in run position at the S-terminal(solenoid connector). I am now at a quandary as to which direction to go. Ignition switch, wiring, etc?
Apr 25, 2007 at 3:23 PM
