1996 Ford Taurus Will not start
186,000 MILES • 6 CYL • FWD • AUTOMATIC
COKHILLBILLY
  • 5 POSTS
The car quit while taking a off ramp my wife coasted to a parking lot. I checked the car and it would not start. It just clicks like a dead battery. the battery is strong so i thought it was in the starter but it is turning over and then checked the oil and it was not even on the dip stick. So is there a way i can check to see if the motor is locked up and if so is there a way to unlock it. thank you.
Dec 26, 2007 at 10:29 AM
BMRFIXIT
  • 19,053 POSTS
[quote:2e5f2cace5="cokhillbilly"]Engine problem
1996 Ford Taurus 6 cyl Front Wheel Drive Automatic 186000 miles
The car quit while taking a off ramp my wife coasted to a parking lot. I checked the car and it would not start. It just clicks like a dead battery. the battery is strong so i thought it was in the starter but it is turning over and then checked the oil and it was not even on the dip stick. So is there a way i can check to see if the motor is locked up and if so is there a way to unlock it. thank you.[/quote:2e5f2cace5]
1st add oil try to turn the engine by placing a wrench on the crank and try turning the engine
and if no luck engine no good
Dec 26, 2007 at 10:58 AM
