1996 Ford Taurus water pump
156,000 MILES • 6 CYL • FWD • AUTOMATIC
MILLI752
how to change the water pump
Dec 11, 2007 at 1:47 PM
BMRFIXIT
  • 19,053 POSTS
[quote:683e17c38b="milli752"]Engine problem
1996 Ford Taurus 6 cyl Front Wheel Drive Automatic 156000 miles
how to change the water pump[/quote:683e17c38b]
engine size will help a lot
disconnect negative battery cable
drain cooling system
remove drive belt
remove radiator hose
remove AC compressor to pump brace
remove pump
clean surface
good luck
Dec 11, 2007 at 1:57 PM
