HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Taurus
Engine Cooling
Water Pump
Replace/Remove
1996 Ford Taurus water pump
MILLI752
MEMBER
1996 FORD TAURUS
6 CYL
FWD
AUTOMATIC
156,000 MILES
How to change the water pump
Tuesday, December 11th, 2007 AT 9:47 PM
BMRFIXIT
MECHANIC
Engine size will help a lot
disconnect negative battery cable
drain cooling system
remove drive belt
remove radiator hose
remove AC compressor to pump brace
remove pump
clean surface
good luck
SPONSORED LINKS
Tuesday, December 11th, 2007 AT 9:57 PM
Please
login
or
register
to post a reply.
Related Water Pump Replace/Remove Content
1996 Ford Taurus
I Have Already Changed The Water Pump And Took The Thermostate Out But Still Leaking Water Out Of Reserve Tank Cap What Can Be Wrong. The...
Asked by
toleta quezaire
1996
FORD TAURUS
VIDEO
Water Pump Replacement
Instructional repair video
Water Pump Removal - Problems?
Have A 3.0 Dohc And Am Replacing Water Pump. Was Able To Get 3 Of The Nuts Off The Pump Bracket And Removed The A/c Bracket Piece But...
Asked by
brolland
6 IMAGES
1999
FORD TAURUS
Replace The Water Pump Because There Is A Leak
2001 Ford Taurus Ses 3.0 V6 I Want To Replace The Water Pump Because There Is A Leak But What Is The Name Of The Part That Connects To The...
Asked by
ryantonymitchell
2001
FORD TAURUS
2002 Ford Taurus Water Pump Replacement
My Dealer Is Charging $695 To Replace Water Pump. They Said The Pump Cost $127. Seems Like High Price For The Labor. Is This In Line?
Asked by
Joel Griffith
1 ANSWER
2002
FORD TAURUS
2001 Ford Taurus Water Pump Replacement
What Is The Average Cost To Have A Water Pump Replaced By A Mechanic?
Asked by
amy_dais
2001
FORD TAURUS
VIEW MORE
SPONSORED LINKS
Coolant Leak Repair
Cooling System Pressure Test For Leaks
Online car repair manuals
