Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Taurus
Drivetrain
Transmission
Vehicle Speed Sensor
Replace/Remove
How difficult is it to remove the VSS
1996 FORD TAURUS
156,000 MILES • 6 CYL • FWD • AUTOMATIC
JIM2879
MEMBER
1 POST
How difficult is it to remove the VSS housing?
Aug 12, 2009 at 2:36 AM
RACEFAN966
Experienced Mechanic
Ok here is a pic of the VSS. You just remove the cable from it if you have a speedo cable then remove the one bolt and then twist and pull. Now this sensor isn't that expensive runs about 15 dollars so I would just replace it.
Apr 13, 2021 at 12:53 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
