1996 Ford Taurus turn signals
101,500 MILES • 6 CYL • FWD • AUTOMATIC
FLASHHEAT
  • 8 POSTS
Is there a relay or some other "larger fuse" that could cut off my turn signals and emergency flashers? I already checked the flasher unit and its fine, as well as the two fuses under the dash (1 for the hazards and the other for the signals- top right and third column 4th from bottom). Is there anything under the hood that could be blown or should I start looking for a short? Any help would be appreciated.
Dec 28, 2007 at 4:55 PM
DARTGUY
  • 5 POSTS
THERE ARE TWO FLASHERS UNDER THE DASH. DID YOU CHECK BOTH OF THEM. IF YOU DID THEN IT SOUNDS LIKE YOUR MULTI FUNCTION SWITCH IN THE STEERING COLUME HAS GONE BAD.
Dec 29, 2007 at 3:30 AM
