My 1996 ford Taurus' transmission is slipping and doing some odd things. Sometimes it hesitates to go in the lower gears, it will rev up and then go into gear. Other times while turning it will come out of gear and not come back in until the car is straightened out. I have not flushed out the fluid but the fluid level is good. Once the car gets to highway speed the car runs flawlessly. Do I have a bad tranny? My uncle's Taurus had similar simptoms and told me he had a sensor in the tranny replaced and it seemed to fix the problem. Could it be just a sensor? If so, what is this sensor called and where can I get it?
Apr 5, 2010 at 7:48 AM
