1996 Ford Taurus Transmission Problem
15,000 MILES • 6 CYL • FWD • AUTOMATIC
SEDEERING3
In cold weather i start the car put the car in drive and it will not move. After it warms up or i put the car in reverse it will move. After car warms up when i come to a stop for a prolonged time the car shifts out of gear. I then put it into neutral and back to drive and it goes. Shifting is all fine once car gets moving. Ive had no codes or check engine light. Any advice?
Jul 12, 2008 at 9:49 AM
KHLOW2008
  • 41,812 POSTS
Hi sedeering3,
Seems like the trans is getting old. Have you checked the fluid level and condition?
If fluid had not been changed for a long time, try changing it to see if it helps.
Jul 12, 2008 at 5:24 PM
