1996 Ford Taurus transmission hoses
JEPST14
  • 1996 FORD TAURUS
  • 6 CYL
  • FWD
  • 151,500 MILES
I found out my hoses coming from my transmisson was leaking tranny fluid all over the ground. I just took it apart on the driviers side with the wheel off and the plastic off and checkd it out. The problem I saw was that there is a "bridge" looking thing connecting these two hoses and its leaking right were it connects on the right side. I cant figure out how to get that bridge thing off and if I do what to do next. Or how to fix it. It drips contiuously onto the frame then the ground. Any advice would help. Thanks!
Saturday, October 16th, 2010 AT 7:29 PM
BMRFIXIT
  • 19,053 POSTS
Right side !
Are you sure its tranny line and not the power steering cooler and lines?
Monday, October 18th, 2010 AT 6:09 AM
JEPST14
Actaully it is the power steering line. I found that out today. I was told to cut the metal line and connect rubber transmission line to the part you cut. But on the other side I need to put a metal piece on then connect it to the rubber hose. It sounds easy but could be problematic. Thanks again. But does this sound like a resonable solution? Without replacing the whole unit thing?
Monday, October 18th, 2010 AT 1:05 PM
BMRFIXIT
  • 19,053 POSTS
Yes you are correct no need to replace the whole unit
Monday, October 18th, 2010 AT 5:11 PM
