1994 Ford Taurus transmission fluid leak somewhere around?
DENNISDAUB2004
  • 1994 FORD TAURUS
  • 6 CYL
  • FWD
  • 150,000 MILES
Runs fine as long as level is maintained, need to add fluid evey couple of days.
Tuesday, April 8th, 2008 AT 4:27 PM
FLEXY5
  • 512 POSTS
What is the leak near?
Tuesday, April 8th, 2008 AT 10:30 PM
FLEXY5
  • 512 POSTS
Most common concern for front seal leaks is the torque converter. The have a tendancy to swell a little when they overheat. They then damage the seal. The seal and the torque converter will need to be replaced. But if the fluid condition is bad enough, you need to consider the fact that it may not be worth repairing with the high mileage.
Thursday, April 17th, 2008 AT 10:07 PM
