1996 Ford Taurus transmission
GRUMPYMOOSE
Transmission problem
1996 Ford Taurus 6 cyl Front Wheel Drive Automatic
wife started car up and noticed that she had to put her foot into it to get the car to go....it would slowly get up to speed and everything seem to be alright....took to shop and thy say complete overhaul.....so i have a truck that does the same thing and a shop says 2 parts.. and it would be fine ...dont know....the taurus has 161500 miles on it .....what do you think the problem is ....i think they said code was po785 what does that mean 2 me ...... thanks
Jun 24, 2008 at 11:45 AM
AMRAAM35
  • 39 POSTS
code P0785 is the Shift/Timing Solenoid. You dont need to overhaul the transmission to get that, but some transmissions though, you have to remove the transmission from the car to get to it. that may not be your whole problem though. I would imagine a reputable transmission shop would know that. That could cause the symptoms you are describing. It is hard to tell without more description or actually looking at it. I am not sure about yours.
Jun 24, 2008 at 1:59 PM
