1996 Ford Taurus steering fluid leak
24,000 MILES • 6 CYL • 2WD • AUTOMATIC
RIZVWAH
steering fluid leaking from the power steering pressure switch and coolant tank mixed with oil - need assistance for repair
Mar 13, 2009 at 9:37 AM
  • 31,937 POSTS
Hi there,
The power steering switch is just a screw in switch unplug the connection and replace the switch, as for the oil in the coolant, this can be rather serious, i would make sure that the trans cooler(if part of the radiator) has not failed, and have the engine checked for a head gasket / cracked head problem.
Mark (mhpautos)
Mar 13, 2009 at 10:37 AM
