Hello dcmargotta
The transmission range sensor may need to be adjusted
Disconnect the negative battery cable.
Place the shift selector into NEUTRAL.
Remove the air cleaner outlet tube and the air cleaner housing from the vehicle.
Make sure that the shift selector is in NEUTRAL.
Loosen, but do not remove the TR sensor retaining bolts.
Align the TR sensor slots using TR sensor alignment tool T92-70010-AH or equivalent.
Tighten the TR sensor retaining bolts to 80-106 inch lbs. (9-12 Nm).
Install the air cleaner housing and the outlet tube.
Connect the negative battery cable.
Verify that the engine will only start in NEUTRAL or PARK
Jun 8, 2021 at 6:31 AM
