1996 Ford Taurus starter
LARRY35773
  • 11 POSTS
Electrical problem
1996 Ford Taurus 6 cyl Front Wheel Drive Automatic
ok i had my starter checked 2 times and both times they said it was good. Them problem is when i put it back on and turn the key all i hear is click noise if i get trying it it will turn the motor over slow i have a new battery and even tried to use a booster and still the same. Two days ago it was fine.When i take the starter off it is very hot and the motor hasnt been running.please please help its driving me crazy thanks larry
Apr 21, 2009 at 9:24 AM
  • 75,988 POSTS
Check and test the starter relay thoroughly
Apr 21, 2009 at 9:50 AM
LARRY35773
  • 11 POSTS
thanks for answer so fast where would it be on a 1996 in the front fuse panel? thanks do you have a diagram you could show me? again thanks larry
Apr 21, 2009 at 10:48 AM
  • 75,988 POSTS
The fuel pump relay is in the constant control relay module
https://images.2carpros.com/forum/automotive_pictures/12900_ccrm_3.jpg
Apr 21, 2009 at 4:38 PM
LARRY35773
  • 11 POSTS
thanks ill try that and get back with yall again thanks for all the help larry
Apr 22, 2009 at 12:15 AM
