Hello again, after continually working on this problem I have found out that I have electronic instrument panel without a speedometer cable. So my new question is....
What is this transmission speed sensor autozone part # SU8833 ? Also where is it located on the trans ? Does this part send speed indication to the instrument panel ? I'm sure my problem is centered around the no speed indication. This i think is causing the transmission not to shift. It never shifts out of 1st gear, unles the speedometer is working... HELP !!!!!!
Goliath1
Goliath1
May 14, 2009 at 1:09 AM
