When removing the brake booster, do you have to bleed the brakes first?
Jul 10, 2010 at 8:32 AM
✓Experienced Mechanic
remove the master cylender from the booster (2 bolts) then remove the booster. There should be no need to bleed the brakes if the only thing being replaced is the booster. The only time you need to bleed the brakes is when hydraulic system has been opened.
